Technical Hose connector came out of carb! How to fix it?
Noah500
1971 Fiat 500L LHD
Basingstoke, Hampshire
We had a great run out for the FBHVC/NSPCC Drive-it Day today with Overton Classic Revival, ending up at the Crofton Beam Engines site in Wiltshire.
Long story short: on the way back on A303 doing a comfortable 60+mph it suddenly lost power. I managed to pull off the road onto the verge and it quickly became clear that the top fuel hose feeding into the carb had come off and must have been spewing petrol all over the engine bay 😬. Looking at it more closely, it wasn't that the hose clip had given way but the whole brass connector (the ridged connector piece) had come out of the carb itself. Thinking back, there has been a bit of a fuel smell in the engine bay since I've had the car (3 and a half years), so presumably it has been working loose for a while.
So: is it fixable or do I need a whole new carb, or new head part?
It is a known issue! I caught mine before catastrophic failure, fortunately.
repaired mine by thoroughly cleaning out the hole in the alloy carb cover, lightly 'keyed' the brass spigot and used a JB Weld-type epoxy metal to refix it. Just ensure you don't get the epoxy in the tube (I applied a thin ring around the spigot before inserting it, rather than putting adhesive in the hole on the carb.)
It has lasted well for four years so far.
Alternatively, you can buy threaded spigots, which you'll obviously need to tap the hole for.
Thanks... Sounds like a bit of work either way, certainly more than I will be able to do before getting up at 3:30 tomorrow morning to fly to Italy, returning late Friday night and going to Brooklands Italian Car Day next Saturday!
Any suggested source of a suitable spigot, or will any of the right size do?
There is a company called "Continent Electronics" (be careful, NOT continetAL electronics who are quite a different company) who sell a big range of threaded fuel-line spigots. I have used these a lot, with no problems. If your fuel line is 6mm, go for the 8mm---you will need a couple of appropriate taps---possible a "2nd" and a "plug" and file down the length of the threaded section. Put the spigot in with a touch of "loc-tite". Alternatively, use Peter's method with "J.P.Weld"
Reuse existing brass "spigot" using method described by Ant Knox.
If you don't want to use jb weld use a fuel resistant aerobic thread locking liquid.
Is either method (existing spigot or threaded replacement) feasible to do in situ. If not, do all gaskets need to be replaced? Just asking to set my own expectations and get hopefully all the required parts before I start taking things apart...
Personally I would take the carb off to do the job (whichever method you decide to do) and take the opportunity to renew all gaskets, check that the spacer is flat (on both sides), check that the carb flange is flat and generally check that everything is "tickety-boo"
OK, carb off and cleaned up. A couple of the gaskets were a bit brittle and the bottom one (on top of the tray) had some gasket sealant as well as the actual gasket, so I might use some when I put the new one on as well (though both surfaces seem to be flat...). I've ordered a 'Overhaul restoration kit' which includes gaskets, and an M8 threaded brass hose tail. I've tapped the hole in the carbo top to M8x1.25 (same as the hose tail) so I should be good to go when it arrives.
Question about tightening up the new hose tail - I've got some thread lock, or Gorilla super glue; what would be best to lessen the likelihood of the brass thingy coming undone? Actually, I may have a split washer, so that could help too.
OK, the threaded hose tail arrived yesterday, and the carb restoration kit today. The kit included gaskets, a couple of washers, new filter, and replacement needle valve and holder (technical terms? :))
I had to tap the hole a bit more, then cleaned it all up and put the new hose tail in, tightened it up having squeezed some Gorilla super glue gel around the final few threads, then left it to dry.
The old gasket between the bottom of the carb and the drip tray thing had some sealant/gasket make in it, leading me to believe that the carb had been overtightened at some point, distorting the bottom of the carb so it didn't sit quite flat, so I rubbed down the bottom surface on some wet and dry paper placed on a flat surface.
I cleaned off all the old gasket debris and cleaned up the mating surfaces. The interior of the carb didn't look too bad but I cleaned it up just in case. I didn't replace the jets or adjust the idle and throttle settings, on the basis that they were OK before.
Then it was a case of putting it all back together:
  • new top inlet filter
  • new washer for filter plug, tightened up
  • needle valve holder with washer fitted to the top plate, then valve placed in
  • new gasket placed on the underneath of the top plate, old float refitted and the gap adjusted to 7mm
  • top plate screwed down firmly (tightened cross-wise to minimise distortion)
  • air intake elbow bolted on with a new gasket
  • drip tray place over the studs on the block with a new gasket
  • built-up carb placed on the studs with a new gasket and nuts tightend up
  • fuel host connected up to the new hose tail
  • carb cable reconnected
  • throttle lever reconnected
  • other fuel hose clips checked and tightened
I then started it up with some trepidation... and it worked! I let it run for about five minutes, monitoring for any sign or smell of fuel in the engine bay and... nothing! Fingers crossed that is it, though I'll take it out for a run tomorrow to check.
  • 2025-05-08 08 Weber 26 IMB carburettor refurbishment.mp4
    13.2 MB
Well done---let us hope that ally our work leads to good running.
Also: I think "needle valve" in my previous post should be "float valve"
Or maybe it should be float needle valve?
But then again, maybe it should be fuel-level float needle-valve?
Or it could even be carburettor fuel-level float needle-valve? :geek:
Do you have a part number, :devilish:
Just so we all can comprehend which part exactly you're referring to?
:giggle:
Those brass fuel pipe stubs rarely come loose unless someone has applied excessive force when disconnecting the fuel supply hose(pipe) - Fiat originally used 'Cavis' brand plastic fuel hose, this could become very hard over time and therefore difficult to disconnect (note: past removal? marks on brass stub).
The brass pipe stub has a number of small circular rings on it's outside diameter designed to secure it in place after initial fitting :-
Also, after the brass pipe stub has been inserted into the carb. top cover, the alloy area around the brass stub is peened to further lock the stub in place:-
My preference would be to use a fibre washer to seal the new (brass) hose tail, rather than rely on any sealant.
I wouldn't worry about the new hose tail coming undone, it'll be prevented from loosening by the fuel flexible hose being clamped to it.
For anyone who is now starting to worry about their brass hose fitting possibly coming loose or indeed detaching itself from the carb top cover, here's one suggestion (I have several others :geek:) to hopefully allay your fears :-
Secure the brass fitting in place by running a length of locking wire from under the fuel hose clamp, around the carb top cover projection that contains the fuel inlet screen/filter (large brass nut) and twist the wire to tighten (similar to lock-wiring technique used on competition vehicles). Annealed (softened) stainless steel wire is what is usually used but any soft iron wire (garden wire?) should do - I wouldn't rely on copper wire as this can fracture due to age hardening/vibration.
