Technical  Horn location, Croma I.e.
RandomGuy
My horn have stopped working and probably needs replacement. The problem I'm facing is that i can't seem to find the horn. I've looked under the left light were i think most horns are and also under the grill.
So if someone knows the location and maybe a few pointers how to replace/take the old horn out i would be very grateful. Thanks in advance.
I'm not really sure, but i think to remember from dismanteling my Croma that the horn is underneath the left (from behind) fender.
It is in front of the wheel i think, and on the other side should be the windshield washer reservoir.
It was quite hard to get the fender off though, but the horn will just come off with some bolts and a plug.
I have a spare horn here which i can sell for €10,- but it's i'm in the Netherlands so the shipping will be quite expensive
Ok! Thanks for the quick reply guys ill check the locations mentioned above and come back to you. As for the horn ruudw ill first check how much a spare one would cost and then get back to that.
