Currymunster
- Joined
- Apr 19, 2020
- Messages
- 115
- Points
- 28
Trying to fix my daughter's 1.2 8v 2004 Punto.
Hesitate at 3300revs and won't go higher. Fuel consumption down to about 22mpg.
Pulled code using multiecu scan for the post cat sensor. Changed it and it seemed okay. Long journey of 200 miles to university and engine light on and bad running again.
I drove all the way over and hooked up the computer. Same code. So I bought a new ngk sensor. Last one was a known good one which was only hours old.
This time I removed the pre cat sensor and fitted the new one there as the original was a generic cut and shut one. Codes gone. Test drive and still okay. Live data appeared okay.
Came home.
Now it's hesitating again and using too much fuel. No engine light this time.....
So I thought I'd but a catalytic converter tester to and check that.
Am I checking the right thing.....
Anyone got any ideas.....
It also kangaroo jumps when you lift of the throttle.
I thought that might separate issue like an engine mount or induction leak?
James
Came home.
James
