Technical High Final Drive
Keeffy
UK
Hi All, new on here and have a 71' 500f with a 650 engine.
Interested to know if anyone here has a 126 synchronised gearbox with a 9/39 final drive and how they get on with it?
Is it worth the 9/39 over the 8/39 final drive or is the standard 126 gearbox just a better bet?
Cheers, Keith
I used one with a standard 650. I liked it, but eventually reverted to an unmodified transmission when I tried a 594 engine in the car; the change wasn't earthshatteringly beneficial, but I sounded enthusiastic when I reported back.
Hi, thanks for the replies so far..interesting.
My 650 engine is tuned, ported head and 35/75 cam. Really I'm just looking for more quieter/relaxed cruising to be honest.
Could I convert the standard 500 box with the higher final drive and synchronisation or go for a 126 synchro box or the 126p box - Just not sure which way to as I have little experience with theses transmissions..
Hi Keith, I have a 9/39 Diff in my 126 box having taken a while over the merits of a five speed conversion. In the end I decided to go with a diff gear set from a 126 BIS gearbox. The swap over was simple enough, BUT the setting of the crown wheel backlash and the turning torque setting of the drive shafts took a little time to get right. Providing you are willing to do the job you will see some 60mph at approx 4000rpm, which for me is a steady cruise with a tuned engine.
Ian.
Thanks Ian that's really good info, appreciated.
May I ask where you got your Bis gear set from and did it fit straight into your 500 gearbox? Is there a supplier of Bis parts in the UK?
Keith
Hi Keith, I obtained my BIS gearbox from a forum member and changed the diff myself. The change is a simple one for one and then the adjustments to suit, I used the late model 126 Haynes manual as a blueprint for the job. Not sure about BIS parts, I think that you will have to check around the bazaars to see if anyone has a set available, but with the mod getting popular they will be a little thin on the ground. Best to try any scrappers for a box complete or there is the expensive way of buying a set from Italy o_Oo_Oo_Oo_O .
Ian.
Axel Gerstl has brand new 9/39 gearsets. Its where i got mine. I had a lead for a set on ebay. But honestly, it was only 1/2 the price, and i didnt want to take the risk of buying something used that was worn and required such a deep tare-down of the transmission only to find out that it was bad.
Still cheaper then a 5 speed kit, and should suit what i wanted.
Back in 2018, I bought a brand new 9:39 crownwheel and pinion set from a company that doesn't seem to sell on UK eBay any more. The price hasn't changed at Euro199.00, and they do have an English translated website. They seem to have other stuff that some of us would all like to have. Worth a try?
Thanks! I'll check their website out.
Keith
Yes, Axel Gerstl still sell the "Crown-wheel and Pinion" set-----E348 for the 8/39 set (part number C01137/1) or, the 9/39 set for E409, (part number 01071). Alternatively, you could contact Lucasz Reszczynski at LP Garage ( [email protected]) and see what he has to offer----you might find that buying a complete gearbox is the cheapest way to go. If you think that using me (Tom Montagu) as a reference will help, feel free to do so; I have done a lot of business with Lucasz; never had a reason to complain.
Thanks Tom, very decent of you!
I will send Lucasz an email. Thoughts on the quality of Bis parts/gearboxes compared to the Fiat Italian make?
Out of interest also but would all the internals of the 500, 126 and Bis gearboxes be interchangeable with each other would anyone know?
Keith
Keith
No, they are NOT---the 500 has NO synchro, whilst both of the 126 versions have synchro on 2nd, 3rd,and 4th. A friend of mine, who has a LOT of experience building and re-building 500/126 engines and gearboxes was recently asked to do such a 'mix' in order to re-build a 126 gear-box----I never realised he knew so many rude words! Eventually he raided his own extensive collection of parts in order to complete the job. A 126 gearbox can be made to fit onto a 500 as long as you (a) remove the bell-housing off the 500 gearbox and fit it to the 126 'box and, (b) fit 500 drive-shafts to the 126 'box---the 126 drive-shafts are too long.
Keith
I owned a Fiat 126 BIS back in the late '90s and whilst I enjoyed the throwback feeling that made me reminisce about the earlier 500, I considered it to be an appalling car in many respects.
Relevant to this question, the gearbox on mine completely sliced up second gear. Undaunted, I got hold of a scrap car and dismantled the gearbox for spares, only to find the same issue there.
To be fair,it may have been that at 704cc, the engine was kicking out significantly more power than the gearbox was originally designed to handle. If you can get hold of a BIS gearbox you won't be able to bolt it to a 499 or a 652 engine without getting involved in so much work that you may as well replace the worn parts and fit any upgrades to your existing gearbox.
The best thing to do is to replace the 499 engine and gearbox as one chunk with the aircooled 126 versions. The most involved part of doing that is replacing the driveshafts, which once you've done it,, looking back, seems quite easy; maybe not so much when you're first tackling it.
You won't lose out on the "pleasures" of non-synchromesh as the chances are that your 126 box will have pretty crappy synchro in any case. ;)
Hey guys a guy was selling yesterday a 10/39 pinion crown and did some research about it so here I am. 10/39 looks more than my 40hp 650 needs so I am starting to think for a 9/39. @the hobbler Tom you have an email address of this LP garage. Is this guy in Poland?
Good morning Thomas---the e-mail address for Lukaz Reszczynski is:--- [email protected] Lukasz is based in Sudbury, Suffolk. I have had 2 gearboxes from him to fit into 500s, and although they were both 2nd hand, there has been no problem with them. BUT always remember that they ARE 2nd hand, so there will always be an element of "pot-luck"
Something to always keep in mind when one thinks about putting a higher ratio diff into the gearbox is---will the engine pull it? There is a chance that too high a diff ratio will actually REDUCE the car's top speed as the engine will not be able to attain the revs required to gain any greater top speed. Also, fitting a higher ratio diff will adversely affect the acceleration performance of the car
Hi Tom, well my engine is tuned and so far with the stock 650 GB looks like it needs a longer ratio, even at steep hills and I mean steep little car like to accelerate than decent so my guess is that 9/39 will fit perfectly. I am not in a hurry though since my car now is at the shop for general reconditioning and painting so I will be busy when I get it back but I will think of it, maybe find a second GB rebuild it and swap it I'll see.
