I stand to be corrected , but that seems high for idle.Another question van is still rough idleing but I connected the tourqe app and its showing over 15000 psi fuel pressure in idle is this correct?
I have a 2010 Fiat Scudo with the 2litre Peugeot RHK version of your 2.2 engine and was told recommended injection fuel pressure was 150-1350 Bar, roughly 2,205psi to 19,854psi.
Mine has some issues but reads 290Bar at idle and a max of 1000bar roughly at 3000rpm and has not greatly varied with a different s/h Siemens injector pump and a new fuel regulator, though the pump got rid of the higher end misfire.
Did you fit the four recon injectors you mentioned earlier?
My ongoing is issue is a light top end rattle above 1500 rpm approx. that appears, using stethoscope to be coming from the injectors and common rail, starting is not a problem hot or cold, though this is sunny Devon
