Hi!! Punto Problems!
amandafek
Hi, im new to the forum and i hoping that somedoby will be able to help me......
My passanger rear wheel squeaks really loud and had developed a slight wobble?!
Anybody have an idea whats wrong and how to fix it?!!
Cheers!! :)
Welcome.
When you mean squeaking, can you describe what the sound is more like, is it a rubber type noise, or metallic sounding. To be it could be the rear brake drum/disc/pads seized or worn. Wobble doesn't sound too good, have you got a wheel brace, jack up the car, remove the wheel, take it off and inspect, then replace and torque the bolts back up.
This is safety so don't drive the car till it's done.
Probles solved...
Squeeks are the shocks, and the wobble was a slightly bent alloy. Thanks !
Probles solved...
Result cool!
Both dampers should be swapped as a pair remember, and I'd swap that alloy, it could suffer a stress fracture & blow out.
