Hi i am new and have mot problem
diamondgeezer26
st helens
Hi i have just had a fail on my fiat stilo 1.6 16v hole in exhaust back box it is an ansa exhaust
does any one no where to get a new one from this is my first mot i was shocked i thought it would pass easy(n)
Hello and welcome :D
Bad luck with that one :( If it's just a small hole, a patch with some gungum and coke can should suffice. If it's a larger area, the garage that did the MOT should be able to fit you a new back section easily and cheaply enough. Once the backbox goes, the piping around it is often on the way out as well so it's worth checking that out before deciding to replace the backbox only.
youve alraedy asked this and someone has already given you a link to where you can get a new one! :rolleyes:
this section is for introductions not problems (y)
