Ducato Hi and Help Please
Knottyjune
Hi just joined this site, so glad it and yourselves are here, I need advice. I have just bought a Ducato 2005 diesel van, which I want to make into my little camper van, previous owner said get new glow plugs, had those fitted today, driven around in her fine, parked up tonight and went to go out to my daughters after 3 hours and it won't start, any ideas much appreciated, is there a machine that garages have that can tell me what's wrong, from non travelling camping lady. june:mad:
Hi your must be 2litre jtd start with something simple how’s the battery condition , fuel , flux capacitor working? Give us some more clues warning light on dash ?
Hi and thank you for trying to help me out, van is a 2 litre, it has a new battery and is turning the engine over just not kicking in. Now can you tell an old lady in easy means what your next items would be too change or check please, and once again thanks June
You defo not accidentally put petrol in it sorry but in does happen ,next question does it sound like it got compression take oil fill cap off rocker cover get friend to turn engine with key look in engine can you see cam turning do NOT put anything in filler hole !!!other that that you’ll have to get a garage to plug machine on it happy new year
Welcome to the forum :)
Diesel engines need 3 things to start - fuel, air and compression. Air is pretty much a given (unless you live in the vacuum of space!), compression is likely to be OK if the engine is freely turning over so fuel supply would be my suspicion.
FYI, glow plugs are only used during initial start-up to pre-warm the block to make ignition by compression easier.
Nowadays they need a lot more to start e.g., immobiliser off, cam and crank synchronisation, sufficient cranking rpm to produce sufficient pressure in the rail before the injectors will be fired.
OP still hasn't confirmed if there are lights on on the dash.
First of all when you turn the ignition key to the first position the key light on the dash should come on then turn off. If it goes off the immobiliser is OK. You should also hear the lift pump running in the diesel tank for about 20 seconds after you turn the key the first position. This is located under the cover by the passengers feet so listen in that area. If no lift pump running the next thing is to try resetting the inertia switch on the firewall behind the battery.
If the lift pump is running and the immobiliser light is off and there is no code light on then the next thing to think about is does the battery have enough charge to turn over the engine fast enough to produce sufficient rail pressure. If the engine is d turning over slowly it won't start if you suspect this then try jump starting from another vehicle.
With all that said glow plugs are not required to start in this kind of weather so the cynic in me thinks the seller may have been aware of starting issues when they sold the van. If the previous steps were unsuccessful the next port of call for me would be read the error code and check the leak off from the injectors.
