Adding to the last post...
Been informed Fiat original filters are also made from fabric.
Possibly these...
Get contaminated with dirty fuel?? Clog too easily and cause fuel starvation?? Get overlooked/forgotten about at services??
After our experience, could ask an independant garage to replace your fuel filter with a "Fram" paper alternative (Fram is a well known aftermarket filter manufacturer) if allowed with the warranty.
Please ensure they keep the original for you to check and let us know the results to help other owners.
Double checked our cars service history.. shows filter was replaced at
41,551 miles by main dealer!! Car had only done under 55,000 miles when purchased with its issues from another main dealer !!
At the mo... 1000 miles covered since filter changed and still accelerating like new without the flatspots...
Will try to keep post updated on how our car is behaving at higher mileage.
Sadly, there is no way of checking the condition of your filter other than to remove and open the cannister.
Not easy... took us 3 attempts to tighten the cannister lid to create a good enough seal when reassembling.
Two special tools are meant for this job... one to hold the round bottom half of the cannister in a vice... the second to fit over the top and remove the thread on the lid. These are too expensive to justify.
Did ours with a workbench vice, hammer, large flat screwdriver and gently tapping the top thread to remove and replace the lid... risks cracking the plastic!
If you have yours replaced.. worth checking the next few days for fuel leakage/seapage around the cannister lid seal and fuel lines for peace of mind.
These are awesome, understated cars when running as they should be and are sadly getting some bad press at the mo.... perhaps due to costly mis-diagnosed faults. :nono:
Love ours to bits now its sorted.
