General  Help!
General  Help!
Devon
I'm hoping that someone can help me, I've recently bought an Uno 45 Fire, and today tried to replace the gearbox (4 speed and whines a bit) with a five speed box from a Panda that I had lying around. However when I came to bolt it in the front gearbox mount is different for the two cars (as the new one is slightly longer), and now I have to either put the old box back or try to find a mount to make it fit. Does anybody know if the 5 speed boxes on Pandas and Unos are exactly the same, and if so hopefully I can find a bracket in a scrappy somewhere. Much thanks for any help, and hopefully the car can be reassembled soon!
You should ask a dealer for Uno 5speed mounting,even if I didn't well understand which front mounting you mean:I.I've got a 5speed Panda, but the only gearbox mounting is on its rear side, towards the cabin!
Passion has neither brands nor models!
La passione non ha nè marche nè modelli!
(Quite happy dark met. blue Panda driver!)
Once upon a time I understand the main casing of fiat 4 and 5 speed boxes were the same with an extension bolted on to house the 5th gear.
Have you swapped the 4 speed mount onto the 5 speed box?
