Technical Help.
Technical Help.
jeff65
Hi folks, we own an 04 Stilo 1.9 jtd multiwagon and i am hopeing some one on here can tell me where to find the glow plug heater relay and the air con sensor that causes all the problems with my electrics.i have changed the MAP and MAF sensors but am still getting the same problems come up, i read some where it was a sensor on the same wiring loom for the air con. so can anyone please help with the location of these two parts.......:confused: cheers
Hi, Welcome to the FF.
The glow plug relay is attached to the bulkhead behind the engine. (Arrowed yellow in the photo below).
The air conditioning 3 stage pressure switch is located low down close to the left (viewed from the front of the car) end of the A/c condenser.
Davren. thanks thats a start, i might get this on the road by christmas .
now it decides to throw a different code at me that says0110 input air temp sensor which one is that ?
:confused:
The input air temperature sensor is part of the MAF (Mass Airflow) sensor
P0110 = Intake Air Temperature Circuit Malfunction, so it could be a faulty sensor or a circuit problem. Disconnect the sensor and clean both parts with electrical contact cleaner (not WD40). There's a locking mechanism on the connector, but I can't remember how it works. I think it involves the yellow clip and sliding part of the connector to the left before disconnecting it.
