Grande Punto help!
Grande Punto help!
vickyf
Hi all new here and need help with my 56 plate grande punto active 1.2 8v recently had the flexi part of the exhaust replaced due to a hole. Since then my em light has come on had diagnostics done showed up I had a fault with the coolant which is getting fixed on Thursday but for the past week when I start the car it makes an horrendous noise then cuts out it does this a couple of times then it starts??? also feels a little juddery at first as day goes on its fine. I'm getting frustrated as it's one thing after another just now please help thanks.
Hi Vicky and WELCOME TO THE FORUM :wave:
Depending on what the fault code is and what they will be replacing on Thursday, a faulty coolant temperature sensor can give you starting issues due to under/ over fueling.
For any more specific online diagnostics, we would need a description of the noise its making, and also the fault code that is turning your engine management light on. Ie P0123. Increased fuel consumption etc.
Alan
