Technical help with side light bulb
jamesstilo11
daventry
One of my side light bulbs have gone. I was wondering if i would be able to replace all 4 by the removeal of the wheel arch linear... Or is it a bumper of jobby?? Thanks in advance. James
side lights.... first notch on the light switch. theres 4 little bulbs... also will i be able to get to the headlamp motors or will the lights needs to come out for that?
Aha, the park light bulbs. I've done them all (4) with removing both plastic covers on each cluster - from the engine bay - without battery removal. (y)
I have now on two occasions had to replace the bulbs on the left side (Battery side) Best is still to take the battery out, and while replacing the park light bulbs, do yourself a favor, replace all the others as well. Saves you a lot of energy. O yes and while the battery is disconnected, clean the tray and the battery itself. The other side is simple, just un-click the cover and pull the bulbs and you done.
You can also change the bulbs to Philips Blue Vision w5w, it shows a clear white light of 4000k, very very similar to LED, but road legal. Costs around 7£ in Romania for 2. I installed those, and Philips Blue Vision H7 bulbs. The effects are very similar to Xenon. I just don't blind everyone.
Check it out. :)
W5W bulbs: Blusvision w5w.jpg
Standard: Standard.jpg
Blue Vision: BlueVision.jpg
Final effect (h7 also installed): 3.jpg
Pictures made with my phone, no alterations whatsoever.
