General Help with indicators
JusFancy
Bournemouth, United Kingdom.
Hi, I've got a K reg, 1.0 fuel injected fiat uno i.e and I'm having trouble with my indicators. Basically, they've stopped working completely. There's no light, no noise nothing! My hazards aren't working either. Can anybody help? Do you think it could be a simple fuse or bulb problem?
Thankyou
Justine : )
could easily just be the fuses but i doubt all bulbs would go at exactly the same time.
check the fuses and replace as necessary. if the fuses are ok then it may be something more serious.
I had a problem that when i turned the indicators on it would blow the fuse after a few flashes, but the hazard lights would work fine and not blow their fuse. weird. turned out it was because water had got into one of my rear units and made the indicator fuse blow. i just replaced the unit.
i thought it might be flasher unit but don't know where it is on a uno.
Please do not Email or PM me asking for support. Post on the forums instead. Your reply may help someone else. Thank you
Originally posted by JusFancy
Is it difficult to sort out flasher unit? Or exspensive to get garage to do it?
Justine : )
no its easy, just a little plastik box you just pull it out and push in a new one,looks like a relay, on a punto they are blue and sit under the steering coloum but i don't know where it is on a uno, i was hoping one of the uno boys would have a look in there manual and post it up.
Hi it is under the steering coloum on a uno as well,
in the top topic in this uno forum there is a haynes manual in adobe pdf format look on there go to page 94 of 303 and there is a picture of it.
