i just had to replace the clutch master cylinder in my 1.2 03 plate stilo as it was making a massive squeaking the noise is gone but now it wont start..
i had to remove the fuse box inside to get to everything and i plugged it all back in and everything else works but it wont start turns over but nothing..
im worried ive done something it now says ars and ebd failure on the dash and yes i disconnected the negative on the battery before i started work. any help on things i can try or what it could be would be great.
i dont think its a loose connector in the fuse box ill double check again 2moro
does anyone know what fuse is for the Immobiliser if it could be that ?
thanks for reading hope you can help.
alex
alex
