Hi there guys,
Got a question for you.
I have a 2002 Abarth stilo and 2 or so months ago it decided to stop going into gear, so took to my local fiat specialist who found a corroded wiring loom so we replaced that still no selection, we then tried another gbox ecu still to no avail.
Then the gbox was removed where we found that there was a broken sensor on the back of the box. So replaced that. Put it all back together tested all manually and examiner is coming up with the correct reading as is the dashboard. All sensors, potentiometers, have all been tested too.
The problem is that we now cant the Examiner to cailibrate the gearbox...
Any thoughts people?
Theres no many Abarth stilos up here so my mechanic has never came accross this fault.......
Thanks in advance
Thanks in advance
