Technical help regarding steering plz
mjgoddo71
Hi the tipo is finally running, however i'm having problems with its steering which is very heavy and noisy when turning the steering wheel (makes a grinding noise). I've checked and its had a new power steering pump belt fitted, are there any known faults on the MK2 16v steering, and if its a fault with my rack, how easy is it to repair or replace (Got a spare rack with the car).
Any advice or suggestions what to check would be very welcome. I'd really like to get the car road worthy asap.
Thanks in advance
Mark
thanks, i'll check in the morning, i did notice that the PAS resevoir pressure release was popping up when the car was running, i'll guess thats cause its empty!!
