Fiat Ulysse 2.0 16v JTD 2003.
Hello. I have an elm 327 interface and have tried to connect to my ecu to read and clear the fault codes. I have repaired and rebuilt my ulysse engine following cambelt failure, but now the injectors are not working. So i need to clear the codes then try starting the engine and read the codes again to see what the problem is. I have tried fiat ecu scan ( Ulysse not supported ?? ), pcm scan and digimoto but without success. Has anyone had any luck at this ?
