Technical HELP!! power dropping out eng management light on
bigdong
Can anybody solve this one? 05reg scudo 2.0jtd 16v
Fault code showing P1112 which is low pressure on fuel rail. Common cause is the high pressure fuel sensor on the back of the pump which was leaking and has now been changed. The van runs well as long as i keep the revs down and stay below 62mph but as soon as i give it the boot it looses its power as if something was chokeing the fuel lines. Sometimes it just cuts out for no apparent reason and will not restart untill the key has been removed. After restart it runs perfect again until i give it the boot again. If it gets 3 restarts without giveing it the boot the management light goes out but ofcourse it comes straight back on as soon as i try to get power. Can anybody put light on this one? PLEASE!!!
Thanks for all the help folks . Sorted the problem by selling the car. Somebody elses problem now.(y)
