N
Nico
This is re my volvo rather than the mule, but won't matter of course. I serviced my coupe a couple weeks back and changed oil filter and plugs. Since then there's been a bit of a leak.
Now I had a look underneath and could see it dripping from the sump plug so I figure I just hadn't done it tight enough, but has carried on leaking.
Had the bonnet up today to see if it was perhaps a gasket higher up and I found standing oil in the recesses of the top of engine cover and low and behold, one of the spark plu chmabers was full of oil.
The spark plu did nor seem tight, nor did it seem not to come out smoothly once loosended (so I rather doubt I threaded it putting it in).
The leak must have been originating from out of where the plug screws in, but is this possible if the thread was tight????????
Any help much appreciated
