Hello all, i am new to the forum. I have a 2003 fiat ulysse 2 litre 16v jtd that i bought with a broken cambelt. I have stripped the head off and checked the pistons which were in good order, no valves were bent so fitted new head gasket and replaced 6 broken followers.
I have autodata s/ware which shows the timing procedures for the cambelt but it doesn't show the timing relationship between the 2 camshafts ( 1 camshaft ( exhaust ) driven by the cambelt, the inlet camshaft is driven by a chain from the exhaust camshaft ) it is the setting up of the 2 camshaft on the chain that i am struggling with.
I bought a disc off ebay which shows a timing mark on the front of the sprocket on the inlet camshaft which is timed at 12 o'clock when the other camshaft is locked with an 8mm pin. On inspection of my inlet camshaft it is not the same, there is no timing mark on the front of the sprocket but there are 3 dots on the back of the sprocket. Can someone please advise and if possible post a diagram ?
Thankyou in advance
Andy
Thankyou in advance
Andy
