Technical Help please!! Gearbox problem
Teedeeaitch
Hello,
Ten minutes off the ferry at Dunkirque my Ducato based Tabbert motor home stuck in fourth gear.
Our breakdown insurance cover had it trailered to a garage where the guy wiggled the linkage and pronounced we needed a new box. A week later (us camping on the forecourt!) and they announced that it was impossible to find either a used or new box, and that a repair would be too complex for them, so we came home by ferry and are waiting for the van to show up in UK in a fortnight's time.
The van is a 2482cc diesel, LHD, 5-speed manual with a column shift, first reg 1989. The chassis no is ZFA28000000565222.
Has anyone got any ideas about the best way forward now please? Might I find a box, are there specialists who may be able to strip and repair the existing one. Any thoughts would be gratefully received.
Thanks,
Trevor
Hello,
Thanks,
Trevor
You could try calling delfindesigns http://www.delfindesigns.co.uk/index.php?act=viewDoc&docId=2 and cross your fingers. I wouldn't expect a cheap solution though.
Theres also the talbot owners club: http://www.talbotoc.com/ which covers the ducato too.
You could try emailing the owner of that forum direct explaining its an emergency and ask can he help. Tell him you'll make a donation to help keep the forum going.
I should add that there are lots of gear linkage and clutch clearance issues with these old vans so waving the gear lever about isn't what you'd call a diagnosis.
If the gearbox is damaged you may get away with a synchromesh change. These should be available.
If you're looking for a scrap gearbox they changed to stonger bearings in August 1992 so it may be worth getting a later box.
