R
Rob
Hi, Ive just bought the old fella a 1.4 12v brava, and its got a very loud metallic noise from the top end. Its running fine apart from the noise. I took the rocer cover off, and found a broken tappet on no.2 cylinder. Ive bought one replaced it and its no better.
Ive flushed the engine and changed the oil also. Is there a procedure to fit these tappets, as i removed the broken one and broken pieces then just put a new one in. Is this a terminal problem, or is it a expensive one to sort. Thanks for reading and thanks for letting this nebie join your excellent forum.
cheers rob.
cheers rob.
