Punto (Mk2/2b)  Help on headlight adjustment
Hello guys. How are ya?
It's something i realized when was driving earlier and it is a bit worrying about my Punto 16v.
You see, even with the headlights in highest position possible (with the alignment motor), they still just point more to the ground than on the road... I can barely see what is in front of me. Is there any way i can manually adjust them (like an adjustment screw and if there is, where is it located) or do i have to do something else?
Thank you in advance. [emoji6]
If you look at the rear of the headlight you will see some big white or grey knobs, these are the adjusters. you just dial them in and out to move the beam up and down. Whatever you do DO NOT adjust them too far otherwise the adjuster will snap and you'll need to get a new light (speaking from experience here :( ).
Have a look at this advert on Ebay:
https://www.ebay.co.uk/itm/FIAT-PUN...HEADLIGHT-DX-67718585-0046737519/202764549745
In the midlle of the pictures showing the rear of the light there are two grey knobs, by the F in Fiat and F in NSF. Those are the adjusters.
Thank you so much [emoji108][emoji106]
