help on bridging 4 channel amp for 2 subs (pic included)
M
matty
hi all, i need to know where the wires need to go exactly, so that i can wire my system up, the image shows the diagram printed on my amp, i am useless and just do not understand it.
if any one could copy my diagram and maybe ad in the wires on there P.Cs this would be greatfully appriciated,
so.... i have a 4 channel amp, im wanting to run two subs from it, using all 4 channels,
hope someone can help,
cheers
matty
From the diagram Left channel + and Right channel - (Both A) and the same for (B)
Re: Re: help on bridging 4 channel amp for 2 subs (pic included)
so the left hand side is posotive? and the right negative? but to bridge it wouldnt i need to double up one from each side?
im lost lol
Re: Re: Re: help on bridging 4 channel amp for 2 subs (pic included)
is that right or even close? do i use all 4 channels or should i only use 2, some one plz help, cheers btw sy for your help
Re: Re: Re: Re: help on bridging 4 channel amp for 2 subs (pic included)
on your diagram, scrap the pink wires, just use the blue ones putting a speaker where you joined the blue ones.
You will have one speaker connected to row A and one to row B wired to the terminals linked where it shows as bridged.
Re: Re: Re: Re: Re: help on bridging 4 channel amp for 2 subs (pic included)
Your Positive wire for sub A to Left Channel + and the negative wire To Right Channel -,
Sub B you will mirror A
like so
Matty, wire it like that and there will be a BIG bang and no more amp.
Wire it how Alan has shown.
thanks a lots ppl, great help. so i DO actually leave 4 connections pit, this was the bit i was unsure about, i didnt know wether i needed to use all the connections or both,
thanks again
matty
A
1
11K
Angelo
A
F
7K
F1-ANG
F
G
2
917
T
E
1K
E
