Hi there, where the spare wheel is kept you should have a moulded plastic disc with accessories in it, where you will find a plastic adapter which eits into the holes inside the car behind the light cluster, simply undo the cluster from inside the car and remove it, you will see the bulb holder inside the cluster so just simply change the bulb and reverse the procedure to re fit the cluster , should take you about 5 minutes .
