Help needed
Help needed
berns
I am new to this so Hello everyone.
Can anyone tell me how to change the right rear brake light of my R reg Fiat punto.
Well the guys in the punto section will so pop down there and ask them.. welcome to the forum..(y)
Hi there, where the spare wheel is kept you should have a moulded plastic disc with accessories in it, where you will find a plastic adapter which eits into the holes inside the car behind the light cluster, simply undo the cluster from inside the car and remove it, you will see the bulb holder inside the cluster so just simply change the bulb and reverse the procedure to re fit the cluster , should take you about 5 minutes .
