Hi everyone,
Hoping someone knowledgeable can guide me. My 2013 Fiat 500 TwinAir Dualogic semi auto has recently gone into the usual “stuck in Neutral” situation and won’t select gears at all now. The issue with gears being stuck and not selecting has been happening for over a year and I just have needed to switch off and switch back on to resolve it but a few weeks back it discharged a burning smell, smoke from
Bonnet and a constant screeching sound when car is running and it won’t select gears at all.
I had a basic OBD scan at a local garage (I’m trying to understand what’s most likely before committing to a Fiat dealer scan MultiESUScan) and these were the results:
NO faults in:
• ABS
• OBDII permanent codes
• OBDII pending codes
Faults found:
Engine Management: 2
– P065B | (OEM description needed)
– P0700 | Transmission Control System (MIL request)
Body Computer: 1
– U1411 | Battery Sensor (IBS)
OBDII Codes ($03): 1
Questions:
1) Given these codes, can anyone advise realistically what I might be dealing with?
Possibilities I’ve been told include:
• Clutch
• Actuator
• Flywheel (DMF)
• Pump/pressure issue
• Sensor fault
• Input shaft bearing
2) Is P0700 usually triggered by the actuator or clutch on Dualogic?
3) And could any of this relate to the new alternator + belt replacement I had done a few months ago?
Any guidance would mean the world to me. I’m really stressed and just trying to make the right decision before booking repairs.
Thank you in advance.
NO faults in:
• ABS
Faults found:
Body Computer: 1
Questions:
• Clutch
• Actuator
• Flywheel (DMF)
• Sensor fault
- Year
- 2013
- Mileage
- 42000
