Technical  help multipla inerta switch
nar31k
i have just changed a injector in a 1.6 16v petrol multipla but now it wont even turn over im not sure it i need to purge the fuel system or if it has a inertia cut off swich if it does i cant find it anywhere anyone have any idea where i can find it or what it looks like :):)
What are you getting ?
Dash lights?
Starter turning?
Fuel pump sound?
I know they have a fuel cut off but im not sure about the petrol model but my handbook shows a LEFT HAND DRIVE MULTI with the cut off under the dashboard around where your left knee would go (lhd remember).
have not found switch yet but can hear fuel pump when turn ignition got all dash lights and battery got good charge in it but starter wont kick in . thought would save a few quid changing injector looks like it going to end up costing me more :confused::confused:
Id give all the relays around the car a check , the fuel cut off will silence the the pump me thinks. What did you remove to do the injector id start there first.
