General  Help Is Needed
DONOVAN
Hey Guys I Need Your Help!!
Ive Got A Nasty Fault With My Uno.
About Three Weeks Ago My Car Started Jerking On Pull Away And When Driving Slowly.
I Replaced The Distributor Cap , And That Worked For A Week And Then Started Jerking Again, I Then Replaced The Spark Plugs And That Worked For A Week , Then The Jerk Returned, I Then Replaced The Bogi Cords(plug Cords) , And That Worked For A Week And Then The Jerk Returned Again , Inbetween All This I Replaced My Clutch Aswell.
Any Advice What To Check Or Replace?
Any Advice Will Be Apreciated.
it could be something to do with your fuel pump. Sometimes the connections get corroded causing jerking problems. Worth checking that out. Otherwise i was gona say possibly the distributor but u have changed that now so it cant be that. Let me know how it goes
F R O $ T Y
Hey Frosty I Replace The Feul Filter And The Rotor In The Distributor And That Did Not Work Either , What I Found To Be Faulty Was The Modulator , Ill See How Things Go From There Ill Let You Know , Thanks For The Advice
