SuperUno
Hi all,
I need someone to look under the back of their car for me.
What i am doing is refitting the brake lines on my rally Uno, and i have got to the brake pro-portioning valve i have mounted the valve, but i have forgotten the order i should put the pipes back in, ie does the pipe from the master cylinder go in the bottom hole or the top hole. Or does the pipe that goes across the back of the car to the other side and the flexi pipe go in the bottom or top.
So could someone with a working Uno just pop out and have a quick look to tell which way i should re-fit the pipes. I have checked all the maunals i have (Haynes, Porter, & Halfrauds and the Fiat Dealer one) and as far as i can make out i think it is the pipe from the master cylinder in the bottom and the pipe to the other side in the top.
Thanks for any help.
Matt Endean
Matt Endean
