FiatFleetFamily
Established member
Just been to fill up car. Once cap on closed fuel flap, would not close..Hmmm.
The spring cylinder was not recoiling, not sure if this is the correct name for this.
Once home, I held the flap closed and locked car to ensure the shoot bolt locked flap.
Then returned to unlock car, did so and the flap opened. I took out this rubber ended cylinder held in place with 2 tabs and dismantled, there is a little spring inside and a spring lever, which was corroded and broken.
I have now removed all this to examine, locked car as holding fuel flap to ensure shoot bolt locked flap.
I have searched the Eper system for this part and cannot find it, it shows a hinge and flap and a fuel cap, but not this cylinder, unless I am on a old Eper system.
I will try an take photo and post up, so that you all can see what I am on about.
