Help Fitting Amp Into Punto
FiatJack27
Hey guys,
I own a Fiat Punto Mark 2, 02 plate 1.2 Active this weekend I am going to attempt to fit a 300 Watt sub and amp to power my new speakers. I want to run the power cable/feed from the battery via the gromit located in the bulk head. I was wondering how to locate the gromit from inside the cabin ??? Any input or ideas would be appreciated :)
Cheers Jack
Pull the gromit out with screwdriver or other tool and then feed a thick wire (amp power lead ) through and then go in the engine bay and find where its coming from then you can pull it back through and put the cable through the gromit and replace it.
Thanks thats a great help, do you know roughly where the cable will come through ?? Will I be able to access without removing heater ???
you can put your hand up behind the glove box and get hold of it if it doesn't drop down in to your foot well
it took me ages to find it but it is there
Okay cheers guys much appreciated I will have a go and let you know how I get.
Thanks again
Jack
