maximoke
Hi everybody. I recently bought a 1999 Vreg 1.2L 16V 80SX brava, which had a head gasket problem. I have replaced the gasket, skimmed the head, replaced the timing belt and tensioner, and cammed it up using equal length rods in cylinders 1&2, and locked the cams, but the car wont start. So far I have managed to ascertain I have fuel at the injectors (the pump runs on ignition turn on) it also comes out of the valve on the fuel rail. I have spark on all four plugs, and they are wet when removed. I have re-moved ALL fuses around the car and cleaned them and their holders (none gone by the way), the crankshaft sensor reads 840ohms, and the pulley is fitted correctly with the pin etc. I have all connectors reconnected, and I have also just for luck, even though the fuel pump is running, pressed the fuel cut off relay. If anyone here can help with something I might have missed, or have suffered the same fate please help.:bang:
