Technical help..bolts holding rear wheel cylinders
Anyone know the size of the bolts holding the rear wheel brake cylinders? There are 2 of them and they are refusing to budge and have started to round off..
Sorry, no.
Discs on mine.
Get some heat into them if you can, with a hot-air gun or small gas torch.
A liberal dousing with penetrating oil should help (but not at the same time as the gas torch, for obvious reasons . . . :dead:
11 or 12mm If memory serves me correctly.
I have a brand new cylinder sitting in the shed at home...i can check it later if this helps??
