Hello guys
Hello guys
bigrab
Inverclyde
Trying to help disabled friend with his
Fiat qubo its a 1.3 multijet auto with 33000 miles on it
Problem is it will only go into neutral and reverse when I select drive dosent do anything .doing bit of reading up on it. dual logic gearbox and robot seems to be a major problem with the fiat's so done a scan and it's coming up with p2917-71 fault on gearbox subsystem shift locked actuator stuck .just ordered leads for obd 2 for multiscan software .my first thought is to check the oil level in robot and give it a oil change any other .ideas guys
Hi, did you fix the problem I have the same issue with my car?
Hi and welcome
We have a dedicated DuaLogic thread running, where hopefully you'll find some help.
Common issues with failing seals on older models.
Just be aware it's a pressurised system, needs to be depressurised before checking fluid level, and only the specified Tutela CS Speed should be used.
