Ulysse  Hello and help please
Flin456
Morning,
I've been registered with the forum but this is my first pos so first of all hello!
I'm after a bit of advice please.
I have a 2000 mk1 2.0 16v petrol Ulysse.
For a while now my ABS has been acting up, when I looked at it I noticed the ABS cog sensor (not sure of the technical name) had cracked and was moving around the piece of the wheel it was attached to. Great I thought a nice easy fix as I've seen these on the web for under a tenner, I'll get round to fixing that soon.
Then this week the wheel bearing on the same wheel started making un healthy noises, I took the car to my local garage and asked for a price to replace the bearing and the ABS sensor.
The mechanic told me that to replace the ABS cog I would need to buy a new CV joint as this was part with the ABS cog on.
To replace the CV joint (with the ABS cog) and the wheel bearing would cost £250.
I have 2 questions,
1) Is it possible to replace just the ABS cog as the CV joint is fine?
2) If the CV joint does need replacing is £250 a reasonable price to pay?
Many thanks for your help and sorry for the first long post.
Joe
Well I just replaced the ring on mine, got it off eBay for about £7. Heat it up in the oven, clean up the drive shaft and tap it home.
But maybe you should just look for a replacement strut, probably get the lot for about £50.
When I had my Mk1 I replaced all the front end running gear with new from eBay:
2 Drive shafts
2 Brake Discs
2 Wish Bones
2 Struts
2 ABS Sensors
2 Wheel bearings
(Kept the Old Springs)
If memory served me right it cast me less that £300 (about 3 years ago) and it took me a full day.
I took my hubs to my local garage to have the wheel bearings pressed out and new inserted and he charged me £10 for each.
what a difference it made!
I would replace the entire shaft rather than just the ring it's quicker and easier!
Driveshaft:
http://www.ebay.co.uk/itm/FIAT-SCUD...arts_SM&fits=Model:Ulysse&hash=item461a42b891
Wheel bearing aren't that expensive!
http://www.ebay.co.uk/itm/F-Wheel-B...arts_SM&fits=Model:Ulysse&hash=item2c704ca37e
You can expect your garage to charge you around £40-£60 P/H labour so the £250 isn't to bad.
However you'll be paying top dollar for parts!
Try asking for a fitting price only and get the parts yourself.
you might be surprised at the difference.
Thanks for the replies, they've certainly got me thinking about doing it myself.
If I was to replace the wishbones and driveshafts myself and take the hubs to a garage for the bearings to be done, would I need any specialist tools? I do my own servicing and can replace brake pads and discs etc but not ventured into anything like this before.. Any advice?
Joe
Joe
No special tools required, although a Big socket and long bar required for the wheel bearings and torque wrench for setting the torques of the bearings.
And I've found some of the nuts to be 35 and some 36mm so buy both to be certain.
A quality ball joint splitter just in case too.
Thanks for the help guys, I think it's DIY is definitely the way to go.
Joe
