Hey,
I recently purchased a mk1 Punto 60 sx and am having some issue with the steering at slow speeds. When your trying to park the steering is really heavy, I'm used to non pas cars as I have a couple of cinq, but this Punto seems unusually heavy.
The top mounts were squeaking so I applied a little light oil, which stopped the squeaking. I checked the track rod end, one is smooth in action but firm, the other is firm but notchy, could this cause the problem ? When you turn the steering you can hear the rack & pinion gear going round, I pulled the gaitors back and applied a decent amount of grease, the mechanical noise was less but it made no difference to the steering. Both front tyres are up pumped to 30psi and are like new in tread depth.
I'm out of ideas and don't want to start replacing parts which may be OK. Hopefully somebody might have an idea which I have over looked.
The car drives perfect otherwise.
