Heater
Heater
K
Kevin
Has anyone come across a problem where the heater only works at full speed on a 1.4 Bravo?
Positions 1 through 3 do nothing, position 4 works fine.
Thought we solved this already
Resistor pack required
see same topic futher back, Tom
heater
I cant find the previos post. Any clues please?
Resistor Pack?
heres the clue, go to......
'Heater fan only works on full speed'
heater
sorry forgot to mention found the previous post, fixed problem with new resistor.
Local fiat dealership denied all knowledge of such a fault and wanted the car in for a day to solve the problem.
£20 and no more than 2 minutes fixed it!
Cheers
Re: heater
my heater is not working on any speed, could this be the same problem?
Re: Re: heater
you may find it's your fan motor thats u.s
exrovermech
Re: Re: Re: Re: heater
u.s polite way of saying knackered
exrovermech
Re: Re: Re: Re: Re: Re: heater
how big a job is it to change the motor?
Re: Re: Re: Re: Re: Re: Re: heater
Should have it unplugged and out in 10 seconds. It will probably cost a few quid though.....
It is located on the passenger side footwell - (look up in the footwell, near the door side). Unplug the electrics and remove the screw at the back, then 1/4 turn and it will be out. It will need a bit of a wiggle to get past the harness down there, but will not take long. Before you rushh into buying a new one, check that it does not work when you apply a voltage (start with a low one...).
M
1
548
Dark Lurker
M
403
M
S
5
902
captain kremmen
C
C
489
craig
C
