as a previous poster said, this is caused by bad electrical connections on
the resister plug on the heater assembly, the heat thus generated causing the insulation on the brown and other wires to burn through.
on 2007 on models, this is best accessed by removing the glove box lid.
and cutting a 3 inch square hole in the plastic at the back of the glove box.
cut this hole in the bottom left hand corner.
you will then have easy access to the plug.
i have repaired a number of scudos with this problem and it is always the bad contacts on the plug, not the resisters.
there are 2 ways to cure the problem
1. buy a new plug from ebay, just the plug, not the resister part, and reconnect
the wires from the old plug to the new one.
2 . do away with the need for a plug,(the best cure) and cut the wires off the plug
and solder the wires directly onto the contacts where the plug fits onto, making sure of course,
that you solder the right wire to the right tag.
