vexorg Prominent member Joined Aug 14, 2021 Messages 1,832 Points 564 Jan 17, 2022 #1 2015 pre-facelift car. The right two controls on the heater panel dont light up at night. Are there bulbs in there? or LEDs? Is it one bulb per control or per side? If it is bulbs then what type of bulb is in there?
OP OP vexorg Prominent member Joined Aug 14, 2021 Messages 1,832 Points 564 Jan 17, 2022 #2 Found the answer on another fiat forum, looks like an easy change
Ralf S. Distinguished member Parked in the garage Written a review Joined Dec 3, 2003 Messages 4,403 Points 1,137 Location The land that time forgot Jan 17, 2022 #3 Linky? Rasputin is doing the same ( had it down for a "Spring" job, when it's warmer.. ) Ralf S.
OP OP vexorg Prominent member Joined Aug 14, 2021 Messages 1,832 Points 564 Jan 17, 2022 #4 Would need to search again, looks like you just prise the heater panel off, and two wedge type bulbs, one for each side.
John202020 It's always more involved Parked in the garage Written a guide Joined Feb 5, 2016 Messages 6,057 Points 1,370 Location Tynemouth Jan 17, 2022 #5 I think, slide a piece of flex with the wires removed to grip the glass end of the bulb or something like that to pull out
D decappottabile Member Joined Apr 13, 2020 Messages 128 Points 81 Location Netherlands Jan 18, 2022 #6 It's in the Guides section; https://www.fiatforum.com/threads/changing-heater-control-panel-bulbs.282195/
OP OP vexorg Prominent member Joined Aug 14, 2021 Messages 1,832 Points 564 Jan 18, 2022 #7 decappottabile said: It's in the Guides section; https://www.fiatforum.com/threads/changing-heater-control-panel-bulbs.282195/ Click to expand... So it is, didn't appear on a search for me. Bulb type 2721 appears to be only getting hits on american sites, looks like T5(286) is the british/european equivalent to that.
