T tim shep New member Joined Dec 7, 2014 Messages 13 Points 3 Dec 11, 2014 #1 hey guys my heater stopped working about a week ago or so and i was wondering if anyone knew why 899 sei Thanks!
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,560 Location Liverpool Dec 11, 2014 #2 Do you mean heater or heater fan? If heater, suspect that cooling system needs bleeding. (On Sei, with heater on full.) Possible water leak? If fan, first check fuse. Last edited: Dec 11, 2014
David C Patron member Joined Mar 29, 2005 Messages 1,787 Points 399 Location London Dec 11, 2014 #3 Is your engine getting up to temperature? (difficult to tell I know without a temperature gauge!) If the engine is nicely warm, but the heater isn't, then the coolant valve on the Sei's heater is a likely suspect. Unless you mean the heater fan isn't working.
J Jim Haseltine New member Joined May 30, 2008 Messages 28 Points 7 Dec 13, 2014 #4 David C said: If the engine is nicely warm, but the heater isn't, then the coolant valve on the Sei's heater is a likely suspect. Click to expand... As I found today, the outer of the valve adjustment cable can slip through the retaining spring clip.
