My 1999 2.0l EL with climate has just decided to blow out cool air no matter what temp the display is showing. Up until now it has been fine. The heater fan etc all work fine. The top hose in engine from rad to block is hot and so is the bottom return hose to the rad. The engine temp guage will hover at 90 and the rad fan works. I took off the rad expansion tank cap and revved engine which caused some coolant to come out suggesting the water pump is ok.
There has been no coolant loss and the oil level shows no rise or water in it suggesting a blown head gasket ( I always fear the worse ! )
As the cold weather has now come I'm desparate to sort this out asap.
Anyone have any suggestions as to what it may be,
A faulty thermostat in the engine ?
A blockage or air lock ?
Or a fault in the control panel ?
Any advice or suggestions please as to how to fix this would be very much appreciated.
Thanks,
Oz.
Thanks,
Oz.
