Technical Heater doesn't blow hot air, what's broken?
Tommygunn
Misano Adriatico
My 1997 Punto 55's heater does not want to blow hot air. The three speeds of the fan work fine but all I get is room temperature air. Considering the mornings are pretty cold at the moment, if I switch the fan onto position 1, after approx 10mins of the engine running, I'll get a slight, very slight, amount of heat for about 2 seconds then it will just give me below luke warm air, as if the air is trying to be heated but there is some partition in the way.
I can't leave it on because by the time the air moves though the car and gets to me the inside car temp has cooled it too much and I'm getting wind chill.
Any ideas?
Tom.
After reading something about bleeding the system/air lock etc I decided to check the coolant level - it is well below the minimum level.
I dare say this is my problem.
Tom.
I dare to say it is very probably a faulty thermostat. If original, it is well beyond its life cycle today. IIRC, new aftermarket one (French Vernet) was some 10-15 € where I live. Unfortunately, 55 does not have the temperature gauge to clarify whether or not it is the case.
If he wasn't loosing coolant, a stuck open thermostat might be responsible, but.........
With the number of dodgy thermostats flooding the market at the moment, best leave it well alone!
Any ideas?
Tom.
its your thermostat for sho, remove the old one, buy new (10 squid) and bleed the system, driving with a fail thermostat increases your fuel consumption
https://www.fiatforum.com/punto-mk1-guides/43906-bleeding-cooling-system-8v-16v-petrol-engines.html
