Fawn Shorts
- Joined
- Nov 28, 2012
- Messages
- 19
- Points
- 5
Hiya,
New to the forum, found it whilst trying to find advice on changing the coolant on my daughters Seicento S 1.1litre 02 plate.
Found a brilliant guide by scottishseicento, (well recommend a look) followed it to the letter last night with huge success apart from...
The heater now blows cold and even though the engine is well hot (radiator fan switches on & off).
Measured the coolant i took out (approx 3.2litres) and i seem to have approx 0.5litres still to go back in, guess that is the heater.
Have repeatedly bleed the system via the two suggested bleed points (bulkhead & drivers headlight) ended up burning fingers with boiling hot coolant but still no heat in the heater, got some great blisters on my fingers now though.
Heater worked fine before the coolant change.
I guess it is air in the system but not sure how to get it out if the bleeds don't do it.
Are there any other bleed points?
Can anyone advise?
Have added a similar comment / request to scottishseicento thread but thought i'd try a new thread too.
Need some help, especially as the weather is apparently turning cold.
Many thanks
Can anyone advise?
Many thanks
