Technical  heat gasket
Yuvalgerson
Hello All
I'm replacing a blown head gasket, any one has a good and fast way to clean the gel/oil (the cooling water has mixed with the oil) from the system?
you will have to drain the engine oil and replace with fresh and replace the oil filter; once the engine is back together run it up to temperature then change the oil and filter and the coolant again
