Technical  Headlight Washers Abarth 500
Lisaflew
Hi Urgent help needed, My headlight washers have stopped working, The screen washers work fine and both reservoirs are full, ive checked the fuses and they seem to be ok. Ive sold the car and its being collected Monday!!! please help.
First guess is the pump try the obvious like fuses first then connections
Thankyou John, do you think if I take it in to Fiat and they connect it up to the heart monitor a fault will show before I go ahead and buy pump? Just in case it’s something else.
Ok so it appears they are connected to the headlights and only work when the headlights are switched on so panic over. I didn’t realise this as you can’t see them yourself so I’ve put this info on in case anyone else has the same problem. Found it on google.
