Technical  Headlamp specifications
theboycalledcrow
Today I was cursed and both high beams and one of the low beams decided to die. What are the specs for them, so I can buy spares? I have a road trip planned for next week and I will be driving back at night so putting it off is not an option.
I would pull the bulbs. They always have information on them. FWIW, if you upgrade to LEDs you won't be sorry. Also, clean all the contacts while you have the bulbs out...
So does this mean your coupe was repaired in the end.
You may be best to check your alternator is not giving too higher voltage causing two to blow close together. Especially as your trip is coming up.
Tim
