danishfiatdriver
- Joined
- Jul 27, 2018
- Messages
- 15
- Points
- 3
Hi there!
I've got my self a 2001 Fiat Seicento sporting which I am worried about having a blown head gasket.
The following symptoms are present:
- Coolant disappears from the overflow without any visible leaks (very little though, like a cup worth for every 800 km's)
- Idling very badly with occasional misifires (though this might be an electrical issue, at high loads there's a blinking CHK engine light - plugs and leads are fresh)
- Engine radiates quite a lot of heat inside bonnet and fan kicks in quite often (though we're having a spectacular heat wave here in Denmark at the moment, so I'm unsure).
Here's whats causing my to think there might be another reason for the disappearing coolant:
- There is A LOT of condensation on the inside of the radiator expansion reservoir. Looks like when you're boiling something in a pot with a lid on.
- The car is not OVERheating (no red lights, unfortunately no temp gauge though)
- The car has driven just fine from Copenhagen to Amsterdam and back (1.600 km trip) and a 500 km Sweden trip without letting me down, and/or worsening of the symptoms in the last couple of days.
-No "mayonaise" in the oil cap
-No seeming oil in the coolant
I will be getting an OBD scan tool in the mail soon that will tell me the cause of the engine light and the accurate coolant temp but until then I want to ask:
What else could be causing coolant to disappear and condensation to form in the reservoir? Seems to me like coolant is somehow evaporating.
I've checked the coolant with those turkey-baster things and it's fine both in freezing and boiling points, so it's not to blame. Lots of black grainy material in the coolant though, maybe gasket material?
Oh, and one last thing, there is this faint smell of coolant in the car, not only when the heater is on (which works), but also when completely off. Carpets are bone-dry and so is the underside of the dash.
Please help me guys!
