this happend to my dad someone stole hs stereo by ripping it out as result no wires were visible in car excpet aerial. they must break off inside somewere. he never reaplced his
run a fused feed to the battery for the permanent live
run a ground lead to something metal and bolt like
run a wire to the ignition switch for ignition live
:yeathat: although the Uno doesnt have an accessory position on the ignition, so you'll have to dig around to find one thats live on ignition only (use a multimeter!). From what i remember, it was an orange wire under the steering column.
OR, you can just connect both the red and yellow wires to the constant power feed (on the stereo end) and that will keep it on all the time untill you turn if off fully manually.
Also, if you dont want to run through a fused power wire, there should be a brown wire knocking about behind the center console area - thats the original power wire used for the stereo in the uno. Its part of the circuit that runs the cigarette socket (if you have one).
